It is currently Mon Jul 21, 2025 1:10 pm
PostPosted: Sat Feb 03, 2007 12:18 pm
Hesh, how about the sawdust shaker tecnique like Robbie does?
PostPosted: Sat Feb 03, 2007 12:23 pm
Hesh, the sawdust and shellac does work pretty well. Prolly wanna tape
off around the rosette though.
PostPosted: Sat Feb 03, 2007 12:44 pm
I would shellac the whole top (minus the rosette) then seal the rosette...
PostPosted: Sat Feb 03, 2007 1:17 pm
First name: Dean
Last Name: Bayles
City: Leucadia
Hesh,
You need to be introduced to Mohawk finishing products. Their Shellac burn-in sticks are the perfect solution to your problem. Buy the assorted color kit. It will last you a lifetime and solve lots of future dillemas. Don't forget to order the hotknife needed you use it. You melt in a blob to overfill slightly and then scrape flush.
Dean
Dean
PostPosted: Sat Feb 03, 2007 1:54 pm
If it were me, I'd float in thick or medium CA. Being careful not to let it seap down the edge of the rosette where it could wick color from your purfling.
PostPosted: Sat Feb 03, 2007 2:02 pm
Hesh, timely dilema and situation. I have the exact same problem on my bench but substitute your BRW for my Wenge...
I am planing on sealing the area with shellac first (but not the rosette itself) and I will then drop fill with thick CA (Hot Stuff) and carefully scrape flush, sand and finish...
PostPosted: Sat Feb 03, 2007 2:13 pm
I usually use gap filling CA after the first couple coats of lacquer are on and squeegee it with a razor blade then sand smooth. Not sure how that would work with FP though.
PostPosted: Sat Feb 03, 2007 2:21 pm
You might try egg whites, that's suppossed to work well under FP. There's some recipes on other threads. Basically just wipe a couple of egg whites stiff until its a hard white foam, then let sit overnite, and then drain off the liquer that will collect at the bottom of the bowl.
CrowDuck
Chris Nielsen
Soquel, CA.
Hesh, I've done it a lot of ways...don't like any of them.
But I think I'd go with Peter's idea.
PostPosted: Sat Feb 03, 2007 3:06 pm
I recently filled my bubinga rosette with Zpoxy and used a tiny scraper when dry.I just left the fill in the pores.I'm going to seal the top with shellac then nitro.
I masked around the rosette carefully.It worked pretty well. That 1/4" masking tape is great for this.Hope this helps
PostPosted: Sat Feb 03, 2007 9:48 pm
Hesh, to be honest I usually don't bother, unless its got really deep pores, it is wood after all. If I do, I use a dust shellac mix drop fill and scrape.
PostPosted: Mon Feb 05, 2007 7:15 am
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
Hesh;
I use the clear pore filler that's sold by Stew-mac .
It's a water base product so it will not stain or bleed woods.
Just apply it once or twice and scrape it smooth.]
Mike Collins
Mike Collins
